This command allows you to restore the order of list-precedence to factory defaults. The default list-precedence is: greylist blacklist whitelist.
greylist, blacklist, whitelist.
Use this command to restore the order of list-precedence to factory defaults. The default list-precedence is: greylist blacklist whitelist.
This command was first available in ExtremeXOS 15.1.
